I'm looking to replace my 10+ year old Kenwood receiver which is beginning to give me trouble. This purchase would be the first step in upgrading my entire system, which is of a similar vintage as my current receiver. I don't want to have to replace this thing for another decade.
This system is used primarily for video (Blu-ray/DVD/HD cable). When we listen to music through it, it's primarily as background; it will not be used for critical or high-volume music appreciation.
Primary considerations (must have):
Secondary considerations (like-to have):
Based on these considerations I'm leaning toward the Onkyo TX-NR709, which seems to check all the boxes. I've also considered the Denon AVR-2312CI (Denon's least expensive model with component video out) and the Marantz SR5006.
Does anyone have hands-on experience (pro or con) with any of these models that they can share? Any other brands/models I should be looking at? Any other features or specs that you feel are particularly important to consider?
- Component video out (to feed my existing HDMI-less CRT display, which I am not wishing to replace immediately)
- Support for multi-room, multi-source configuration (minimum 2-zone, 3-zone would be awesome)
- Support minimum of 7.1 channels
- Price of no more than $600 (I'm not afraid of refurb/open box/gently used)
- Networked w/ DLNA support (AirPlay support is not a priority)
- Internet music support (preferably Spotify and/or Pandora)
- Good Android remote app
- Phono input for the 2-3 times a year I break out the vinyl
- HDMI upconversion from any source (including s-video)
- Support for 4K video (future proofing)
) at the same time.
. My 708 got an all expense paid vacation to SoCal (without me!) to be fixed at their regional service center. The problem my AVR had effected the entire line of X08's and XX08's as well as their Integra line (ie., including their flagship models). I just learned there is another press release from Onkyo that effects many of the X09 and XX09 models! Many are questioning Onkyo's QC process... especially those with units affected
. Many are also comfortable with their AVR's, fortunate to have one that has not been affected
