I am not sure if it is HDMI HDCP handshake compatibility or not.
Issue:
Projector shows HDMI image and consistently drops HDMI signal around 30-40 seconds later, lamp goes into solid orange (power is switch off and cooling lamp). The lamp has around 400 hours and after power cycling 4-5 times consecutively the projector shows HDMI image for hours without dropping signal. Also note that whenever I use VGA no signal problems at first start or anytime later.
Not Working Configurations:
PlayStation 3 (slim)---> 25 feet cable (BJC* Series-1)---> PT-AX100U
PlayStation 3 (slim)---> 6 feet cable (BJC Series-FE)---> PT-AX100U
Blu ray (LG)---> 25 feet cable (BJC Series-1)---> PT-AX100U
Blu ray (LG)---> 6 feet cable (BJC Series-FE)---> PT-AX100U
*BJC = Blue Jeans Cable
PlayStation 3 (slim)---> 25 feet cable (BJC* Series-1)---> SAMSUNG (2280HD)
PlayStation 3 (slim)---> 6 feet cable (BJC Series-FE)---> SAMSUNG (2280HD)
Blu ray (LG)---> 25 feet cable (BJC Series-1)---> SAMSUNG (2280HD)
I value the AVS Forum brainpower.
Wilson
Issue:
Wilson
