I have a benq w6000 and have been using a sheet of drywall as a screen while I finish my theater room(it actually looks great to me). Well its just about finished and I am in need of a screen. I was looking at the monoprice 120" multi-format because of the built in masking system and much lower price tag than da-lite and caradas offerings. Unsure of the build quality of the monoprice screen I have been a bit nervous about plopping down the cash for it, so I figured since my entire theater is diy and so are my subs, I might as well continue going the diy route.
I need to know what paint formula will best fit my viewing conditions. My ceilings are black, walls are taped mudded and waiting for the first coat of paint, I am going with a very dark charcoal grey. I would like to do a screen that is 120"-130". I have some screen samples from da-lite and carada and liked the da-matte and classic cinema white. Is it recommended to spray the screen over rolling it on? I only ask because my good friend is a graffiti artist, so if spaying is best he is the man for the job.
I am also going to build a masking system but that is for another thread. Any help in choosing the correct paint would be great.
I do like the idea of being able to turn the lights up for football games and tv viewing but am mainly concerned about the best black level when the lights are out. If going to a 1.3 gain will not hurt the black levels then I am all for it.
Someday, and it's coming soon.
