AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Music with Pioneer VSX-1121-k
post #1 of 9
So I have my HT setup. A vsx-1121-k. Pioneer monitor 70s cs1 and rears and a klipsch rw12d sub. I like the way my ht sounds for movies, but when I try to AirPlay club music, it defaults to 2 channel stereo it seems, without the sub. What can I do to get the sub to handle the bass during music streaming and how to I have it remember that setting by default.
post #2 of 9
set speakers to small...
set xover to (at least) 80hz...
do not use pure direct...
that should get you what you want...
post #3 of 9
Anyway to set it for just use with AirPlay? I don't want those settings for everything.
post #4 of 9
why not?
post #5 of 9
Glad it's not just me!. (1121-k)
I have the same problem,but read on here today that some one else had the same issue to. Where in stereo it doesn't detect the sub,the guy who posted contacted pioneer and told him set speakers to large and sub to plus
If i can fine that thread i'll link it here. I did try their suggestion and the bass was better.
post #6 of 9
peakier maybe, but unlikely "better"...
virtually all users will get the "best" results by using the method that i posted...
post #7 of 9
Agreed.
The method Pioneer is suggesting will have the sub and mains trying to play the same signal - there's a lot of potential problems associated with that approach (we ignore that the mains can't do it). Boom boom is not "right."
Put the crossover at somewhere between 60 and 90 and set the mains to small; you really aren't "giving up" that much in terms of bandwidth from the mains (so instead of going from 30-ish to some mega-thousand range, you're going from 100-ish to some mega-thousand range).
post #8 of 9
So how do make a setting on this receiver for just airplay?
post #9 of 9
You will have to manually reset the avr for airplay vs tv/ht each time you wish to switch. You were given great advice on setting the speakers to small and X/O at 80 for starters. This will work great for music and HT. Many of us have tower speakers set to small and like the results. Setting the speakers to small does not mean your tower are not good. It is to avoid problems with the system bass management.
