AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › VAS value???
VAS value???
post #1 of 9
Hello
I was wondering if anyone could help me with some values I do not understand?
The speaker is a TINLY TL-3003V
The value of VAS is written as "Vas = 86.951 m M", is it liters, cubic meters etc.?
The same applies to Sd "Sd = 53,093 m M"?
And "MMD = 118.000 m Kg"?
Best regards newbie
post #2 of 9
Nobody can understand those specs. But it does say that the quality is "excellent" in the specs
post #3 of 9
post #4 of 9
The easiest way to look at it is the vas, the smaller the bumber the smaller enclosure it likes. The bl, is the motor strength. Higher numbers mean a more powerful motor force. The mmd is the weight of the cone assembly. None of these necessarily singularly makes a driver good or bad. They work in conjunction with all the rest of the specs which in turn makes the driver good for a specific application. Most pro drivers have high bl but little xmax. Specifically good for producing music loud but not very good for infrasonics. Flip those values around and you have a driver that, depending on some of the other specs, would do well with lower stuff but wouldn't necessarily have that kick you in the chest feeling.
post #5 of 9
Nice and shiny too LOL
After some calculations with the values i do understand i found out that the speaker is best suited with a sealed box.
But i still can't figure out if Vas = 86,951 liters or cubicmeters etc.etc.
And if i use liters i end up with a cabinet which is about 3300 liters with the value of Qtc of 7.20 (should be closest to 0.707)....???? ( I think i have to seal up the bathrom and put the speaker in the door...)
post #6 of 9
Are you sure its not 86.xxxx liters instead of 86,xxxx?
post #7 of 9
And also, were the othe half dozen forums you posted this question on not able to help out with this?
post #8 of 9
Vas = 89.561 Liters, or 3.163 Cubic Feet.
The m M is a misprint as it typically represents Square Meters, which is for area, not volume. Sd is also stated incorrectly which is stated in m M (Sq M). It should read; 0.0531m M. 53 Sq M would be equal to your rooms entire floor space area.
They are obviously using a comma instead of a decimal point in their specs, a common usage in other countries in Europe and Asia. My guess is this is from Asia and there is simply a translation problem in the specs writing department (also common).
Bosso
post #9 of 9
2 Norwegian forums and 3 internatinal and not much info to solve my qustion! In this case half a δεκά forum
" Spread the word and you will be heard" Hopefully
The most promising answer is from Bossobass
Bosso
This is a China speaker and it looks like you are on the spot, thanks a whole bunch
