AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › Replay's blue light is "burned out"
post #1 of 4
My Replay is working just fine except the blue light doesn't show on the front of the unit any more. Is there a way to fix it? I'm not anxious to crack it open if there isn't an easy fix. The light just stopped working one day (like a light bulb that goes bad). The unit responds to the on/off and remote and works fine. Records fine, etc. I just can't tell if it's on or off until I turn on the TV.
post #2 of 4
The front board under the cover frequently has cold solder joints. Unplug the board and touch up the solder joints. or buy a clunker and scavenge a board from it.
post #3 of 4
Not knowing a lot about soldering, but if it was working for the last 10 years, why would it not have a good connection now?
post #4 of 4
  1. Oxidation
  2. Vibration
  3. Burned out
  4. TBD...
  Back to Forum: ReplayTV & Showstopper PVRs
