AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › what is lens shift and what do it do for me
post #1 of 6
i am thinking of getting the epson 3010, but i keep reading about the 5010 and it has lens shift and is about 1000 more.
can someone bring me up to date on this.
I new to projectors and looking for 3d of course.
post #2 of 6
A projector that does not have lens shift (most DLPs) have a set offset.
This means that the image coming out of the front of the projector is shot upward if the projector is on a table or down ward if mounted upside down on the ceiling.
So you have to have room above or below the screen for the projector to sit or the image will not hit the screen properly. This also means when you mount it, you have to get it just right since you have no way to move the image up or down or left or right once the projector is mounted.
If the projector has lens sift it shoots straight out and you can turn a knob to move it up and down and left and right. There are limits to now much you can adjust but it makes placement of the projector much simpler since you do not have to be as exacting or have room above the screen (think low ceiling in a basement) Some offset can require the projector to be a foot or more over the screen top..
post #3 of 6
Does lens shift hurt image quality or 1:1 pixel mapping? For example, I know that when you use Keystoning, you are losing some image quality. Thanks!
post #4 of 6
Not if used sparingly. I have read the issue is you are moving the image out of the center of the lens and you can then have issues created by the lens itself. There is nothing going on with the digital image, this works at the lens end of the projector.
post #5 of 6
Thank you, airscapes.
post #6 of 6
