AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › Sony DVD Recorder RDR GX-300
post #1 of 6
I have a Sony DVD Recorder RDR GX 300 that will not read DVD's and I have numerous unfinalized DVD's since I record certain horse races and keep adding to each DVD. Sony Repair Center in Texas says they no longer make parts to repair this unit which is only about 7 years old. I think that is disgusting. Any ideas on how to finalize these DVD's or find a replacement unit would be appreciated.
post #2 of 6
Check my reply to your post in the other thread.
As for double posting, that's a no-no.
You should post your request for help either here or there, not in both places. Just a bit of friendly advice.
post #3 of 6
Perhaps the OP forgot where he posted before:
http://www.avsforum.com/avs-vb/showthread.php?t=981951
post #4 of 6
My advice: you will need to buy a working second hand RDR GX 300 or a model compatible with your DVDs from ebay or Craiglist, then just finalize your DVDs
After that, you will need to buy or assemble a good HTPC, since the DVD recorders are now dead. Or go TiVo.
post #5 of 6
DVD recorders are not dead, just taking a nap!
post #6 of 6
They will raise again on April 1st.
Anyway you're right, there's still hope for a HD BR-recorder for the US...
  Back to Forum: DVD Recorders (Standard Def)
