I think I'd like to play with a good room EQ equipped receiver. I'll have 2 mains and 2 subs - so I suppose most of the work will be with smoothing the bass response. 99% of the usage will be music, of many styles. I like listening quite loud, but I am frequently forced to listen at lower volume as well.
I know nothing about current competing room EQ products. Audyssey and Yamaha seem popular, but different. There's also the Sherwood R972. So if I want something with decent power for 2 channels (subs will be powered), outputs for subs, and good options/processing/management for bass, what would folks recommend?
Full disclosure - I am firmly in the Richard Clark 'properly engineered amps are indistinguishable' camp. But I also favor products that last, so reliability is important to me.
Thank you.
Thank you.
