There hasn't been much coverage of the HTPC capabilities of the new Kepler GPUs from NVIDIA. I hope we can use this thread to exchange information and provide tips on using a Kepler GPU in a HTPC.
The important HTPC features available in the Kepler series (in addition to whatever was provided by the Fermi family) are:
1. Support for 4K H.264 decode (VDPAU Feature Set D / VP5): Not working as of launch time with software from ISVs. Hendrik might need to update LAV Filters too, but, as of now, it is not clear whether it is a driver issue or software issue. Anyways, this is the spec on paper.
2. Support for H.264 encode: A competitor to Intel's QuickSync and AMD's VCE. Claims fast encode utpo 4K x 4K resolution, but, worked in practice only upto 1080p at launch time. Again, not sure whether it is a software issue or driver issue. Quality seems worse than QuickSync at launch time (detailed coverage from AnandTech may come later. Unable to find any detailed comparisons on other sites)
3. Full support for HDMI 1.4a : Ability to drive 4096 x 2160 at 24 Hz over a single HDMI port. (Will be testing this out shortly).
4. Support for 4 simultaneous displays
