AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Samsung UNXXES6500 Owner's Thread
Official Samsung UNXXES6500 Owner's Thread - Page 15
post #421 of 574
Originally Posted by smidley View Post
Turned on my TV and it said smart hub update coplete. I checked the version, and it's now on 001024. Is that the new version? If so, does anyone know what issues were fixed?
I believe I read up-thread that there is a 1025 version but with recommendations to *not* update. However, my 46ES6580 has ver. 1025 and seems to work perfectly except for the smart hub flash (which is no big deal now that I know it is "normal"). Thanks to bweissman for verifying that those flashes are what others are seeing.
I did find some Advanced Setting recommendations up thread. But so far I've seen no reason to change other than in the basic settings (black level, contrast, etc.). Good sources are excellent on this set. No great blotches, no disturbing motion effects, etc. Apparently some of these issues are confined to sets having larger screens than mine, or so I hope smile.gif
Phil
post #422 of 574
That's the TV's firmware. I'm currently running 1025. The Smart Hub app version is different.
And, speak of the devil and the devil shall appear.... I, too, received a Smart Hub update this afternoon when I turned the set on to watch The Daily Show during lunch.
The flash issue appears to be fixed. The new Smart Hub version is 4.5311-5.0
post #423 of 574
Excellent! Thanks for sharing this info! Any idea if that was the only issue addressed?
post #424 of 574
No idea. Any issues you had in mind?
post #425 of 574
Thanks. I'll see if I can install that.
Phil
post #426 of 574
There was the issue with the flickering if you had the yahoo social widget installed or something. It was talked about early in this thread.
post #427 of 574
Dunno... don't use it.
post #428 of 574
Phil
It's hard not to install. Simply turn on the set and if it has a network connection, it will update. Smart Hub is very aggressive about that. You can find the version number from inside the Smart Hub by pressing the Tools button on the remote. I'm not in front if it right now, but menu navigation is pretty obvious from there.
post #429 of 574
Thanks. I found out about "aggressive". Went Smart Hub and it had already updated to that version. I've not yet noticed if it fixed the smart hub flash issue, but no flashes yet.
I did set up Amazon Prime and Netflix streaming while I was there. Most movies look very good.
Phil
post #430 of 574
I have had this version for a while and mine still flashes.
post #431 of 574
My issues with the smart hub flashing appear to be fixed after the recent update.
post #432 of 574
Likewise. I've not seen a Smart Hub flash since doing that update two days ago.
Phil
post #433 of 574
Phil
I think I'll wait a little more until I apply the update since everything is still working fine after disabling the network.
post #434 of 574
But doesn't that eliminate such things as:
  • Streaming from Amazon and Netflix
  • Firmware and software updates
I guess if you have the TV free standing, no sound bar etc., no need for network. But I'm using those features (streaming, for example) and have a sound bar. And with the latest software/firmware the Smart Hub flash has not been seen for 3 days (vs. frequently before the last update).
Phil
post #435 of 574
Phil
It does but I don't use Netflix so it's fine for me. I rarely stream movies and when I do I use my PS3 for that. But I do like the 3D demos in the dashboard, especially food fight.
If you don't see the flash for at least a week then I will update mine as the last "fix" worked for 4 days or so.
post #436 of 574
Long story but I ended up with this TV as a replacement from Samsung for a problem set they replaced (UN40D6000SFXZA) I have it wired directly with an Ethernet cable and it has software version 001024 on it. Should I update?
post #437 of 574
PS I used the calibrations from post 311 - to be honest I think my older set had a better picture.
post #438 of 574
I found this calibration setting to bring the picture to 6500k color on another website. The setting does provide a decent picture. However, I'm wondering if a professional calibration would tweak the picture in even better. In NH there are no local technicians where I live so the only option is the BB Geek Squad.
Any recommendations? Do you think the $250 would really make all that much of a difference and would be worth it? Please share your experience with professional calibration.
Picture Mode Movie
Backlight 16
Contrast 95
Brightness 45
Sharpness 15
Color 50
Tint G50/R50
ADVANCE SETTINGS
Dynamic Contrast Off
Black Tone Off
Flesh Tone 0
RGB Only Mode Off
Color Space Auto
10pt White Balance On
Gamma +1
Expert Pattern Off
xvYCC Off
PICTURE OPTIONS
Color Tone Warm2
Digital Noise Filter Off
MPEG Noise Filter Off
HDMI Black Level Low
Film Mode Off
Auto Motion Plus Off
LED Motion Plus Off
10PT WHITE BALANCE
ON
Interval Red Green Blue
1 0 -1 -1
2 -1 -1 -1
3 0 0 0
4 -1 0 +1
5 -1 -1 +1
6 -1 -1 -1
7 -1 -1 -1
8 0 0 0
9 +1 0 0
10 +2 0 0
WHITE BALANCE
Setting Value
R-Offset 25
G-Offset 25
B-Offset 28
R-Gain 18
G-Gain 23
B-Gain 21
SCREEN ADJUSTMENT
Picture Size Screen Fit
MEASURED CONTRAST (WITH OTC1000)
100 IRE (Y) 55.3625
O IRE (Y) 0.0222
Ratio (x:1) 2493.8063
post #439 of 574
I really like the 2D picture on this TV, but I have found the 3D Blu-ray quailty has not been good. A lot of issues with crosstalk in most if not all 3D Blu-ray movies I own. For example I was watching Wrath of the Titans the other night and had to turn it off part way in and watch the 2D version because the 3D was not good. I notice with 3D Blu-ray movies that things close in the foreground normally look fine, but background items are not clear and have crosstalk. If you adjust the TV to fix the background the foreground images start to show crosstalk. There is not way to make both work. I have a Sony BDP-S470 Blu-ray player that has the latest firmware for playing 3D Blu-ray movies.
On the other hand....I find the Explore 3D Samsung app has great 3D video. Most if not all the videos in the app look great. No obvious problems with crosstalk. Can anyone explain to me why Explore 3D looks so good and 3D Blu-ray movies are just fair??? I have read that LED Active 3D TV's are more prone to crosstalk, but that doesn't explain why Explore 3D looks great. The only difference between the 2 sources is the Sony BDP-S470 Blu-ray player and I have never heard of any issues with crosstalk with that player. Anyone have any insight on how I can resolve the 3D Blu-ray movie issue? Would replacing the Blu-ray player fix the issue?
post #440 of 574
I've only watched 2 3D Blu-rays on my Samsung TV via my Oppo BDP-93, and both looked great (Avatar & Men in Black 3). No crosstalk that I could see.
post #441 of 574
I've not tried a professional calibration, and likely I won't. My take is that the variation in quality of the sources is a significant factor, even now. I'm pretty happy with most BDs and cable channels with the settings I have now. I do have a calibration disk and may eventually use it. Paying someone else to do something I feel competent to do is unlikely.
Phil
post #442 of 574
I've only watched Avatar in 3D (at home and in the theater) -- plus a few other disks at a friend's house. Avatar is exceptional; others I've seen are not.
Otherwise, I'm not all that interested in 3D with today's technology. Since I must wear glasses, I'll need either a set which does not require glasses, or prescription 3D glasses, to make 3D viable.
But it appears, at least for 2012, most sets with the best features and performance for 2D also had 3D -- so little choice in most lines but to go 3D.
Phil
post #443 of 574
I have a Un32ES6500 in a bedroom and was wondering if others hear feedback from the TV speakers when there is bass? Maybe the TV has a problem. Also, I tried using a RCA 27" soundbar through 3.5mm sound out port but I could not control the volume or on/off from television. Any advise would be greatly appreciated.
post #444 of 574
I'm not sure what you mean by feedback. Feedback usually means audio output is being fed back into an input, i.e., a microphone.
Then again, I'm not sure I've ever heard bass from those tiny tinny speakers in my 46".
post #445 of 574
Probably a static sound describes it better. Any thoughts on a way to control power/sound on a soundbar connected to the TV?
post #446 of 574
Does the picture kind of wear in after a couple of weeks? I bought my Samsung almost 2 weeks ago. It took me at least a week to get picture settings that look the closest to natural to my eyes. Even then, the overall picture seemed a tad too vivid. But if I tried to tone it down further, it looked washed out.
So I've left it at the almost perfect but a tad too vivid setting. After an additional week, the picture now looks like it has settled in and is now spot on for my liking. So my question is - could the picture and TV actually settle in or do you think it's me and my eyes have settled in on the picture? Either way it's all good.
post #447 of 574
Thinking about either taking my 6100 back for a 6500 or a Panasonic ST50 – anyone care to chime in why I should choose the Samsung over the Panasonic?
I watch A LOT of the 24 news channels that all have static banners and logos. I see a lot of talk about the ‘IR’ (image retention?) that still persists on the plasmas. Is it going to be more headache than it is worth to babysit it? This was my original concern and now I’m back to it.
I calibrated my 6100 with the 10 Point White Balance last night and it looked pretty awesome with Blu-ray. Would I expect the ‘backlit’ 6500 to be even better I’m guessing? I’m sure the Samsung ‘smart’ features are superior, but I have a Widi device already and would probably upgrade it if I needed anything more in the ‘smart’ department.
It really boils down to the picture quality vs. the hassles of plasma I suppose. Appreciate input.
post #448 of 574
Costco has a deal on the UN65ES6550F right now, so is it any good, what should I watch out for?
Does it have any audo lip synch issues?
post #449 of 574
Originally Posted by avsforumsdsd View Post
So, Just got the 40es6500 today. Haven't had a new TV in this room in about uh, a DECADE. But, I have to say, moving from my 42" Panasonic Plasma EDTV, EDTV mind you, the image seems to be a bit blurry and fuzzy. Doesn't seem sharp in anyway, seems like a muddied image. Now, all I have done at this point is to adjust using some of the settings here. Thanks DAVE999Z. Those settings helped a bit, made things a bit clearer, but still the image doesn't seem, SHOCKINGLY as good as the image I had from the EDTV that only really have 480p resolution. WTW!?
I guess I'm going to have to get the calibration device out again and run through all the settings, numbers., etc..
I did pretty much the same thing. We had a nice panny 42" EDTV in the BR for about 7+ years, worked great. But, I wanted to move it to HD and get some integrated apps. And save some power. I could literally see the power spikes when using the BR EDTV 42" plasma.
Now, granted those professional panny 480p plasmas were EXCELLENT tv's, even with "edtv" ratings. I've got some 50" HDTV's in plasma as well in the LR and GR, and they are also great.
Going from plasma to even current generation LED screens IS going to give a different view. It's not going to be apples to apples, and IMHO never going to be as sharp. There are always trade-offs.
I did manage to get what appears to be the same set up to some nice settings, had to turn off a bunch of regular settings that made things look blurry and some of the motion stuff made it nearly impossible to get sharpness up to snuff.
But, it is odd to think after 7+ year, moving from EDTV and to what is about five generations of set upgrades it almost seemed like it should be an SD to HD experience, which it is not.
post #450 of 574
