Hey Everyone,
We're going to be digging the basement soon, and since I've taken about half of it for a theater, I'm trying my best to do it right!
On the attached, you'll find a dedicated theater space with the third row converted to poker table and PC use (photo/video editing). As a result, I've had to make some compromises...but picture and sound from the sweet spot is a priority.
Any thoughts, suggestions or feedback would be great, especially on:
- Surround speaker placement?
- Acoustic management with the odd wall shapes/dimensions in the room?
- Distances/measurements?
- Seating ideas?
- Riser height & config?
- Etc.
Basically, the only part that is committed is the outside walls...all else can still be changed. One more thing - 10 foot ceilings throughout (minus some space for ductwork at the back, and behind the screen).
Thanks in advance!
Quill
- Seating ideas?
- Etc.
Thanks in advance!
Quill
plan scaled 2.pdf 476.4638671875k . file
I don't know whether I'll prefer the front or back yet, so I need to hedge my bets and have a middle seat in each...
