AVS › AVS Forum › Video Components › Home Theater Computers › Recommend me a case for my system!! Specs Inside !!
post #1 of 6
The thing is I dont want a huge gaming tower I want something i put on my Tv Stand and look good lim,e a Thertere compnet maybe a HTTPC Case ?? But I am prob not gonna find a case that will fit a nice vid card possibly GTX 480 and cpu cooler?? I I am using this pc for a HTPC plus Gaming !! Ty
post #2 of 6
ATX or microATX?
post #3 of 6
post #4 of 6
Current Rig but upgrading Vid Card Soon, not sure what too?
Motherboard: ASRock Z68 Extreme3 Gen3
Processor (CPU): Intel Core i5-2500K Sandy Bridge 3.3GHz
RAM: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800
Power Supply (PSU): CORSAIR GS700
Graphics Card (GPU): MSI Radeon HD R5570 - Looking to upgrade very soon !!
post #5 of 6
What's your budget? There are a couple of nMediaPC ATX HTPC cases starting around $70 + shipping, then the next step up is Lian-Li for around $140-$160 + shipping. I am a big fan of the Lian-Li and nMediaPC cases. You'll of course need to check the case depth for the video card and the case clearance for the cooler.
http://www.newegg.com/Product/Produc...G&PageSize=100
post #6 of 6
- Antec Fusion Remote Max
- Lian Li PC-C60
- LUXA2 LM300 Pro
- SilverStone Crown CW02
GTX 680 (10" long, not terribly long ) has the performance crown right now.
