Hi All
I wonder if anyone can help me?
I have included in my setup the above and a LG LW650T and a PS3 too.
Now connected to the 'Game' input is the PS3. My HTPC (Windows 7) is connect to the 'VCR/DVR' input and finally I've got the HDMI out connected to the panel (Input 2).
The reason I have the panel connected to Input 2 is because if I have it in port 1, then the sound coming back through the HDMI to the amp breaks up every few seconds or so. So to correct that problem, I have the sound coming through the Optical cable in port 1.
Another problem that I have is that now and again when I'm using the HTPC, the screen will go black for about 2 seconds and then come back on. I never have this problem when I'm using the PS3 or watching TV. So I can only assume it is either the GPU or the AMP.
I've tried several brands of HDMI and the problem persists.
So to sum up, I need help with maybe configuring the amp correctly, or adjusting something within the CCC on the PC.
Any help would really be appreciated.
Regards
Wiggo
Regards
Wiggo
