Ok, I am starting to interview contractors for my theater.
Here are the facts:
1000 sq ft of unfinished space on my second floor, plans to finish ~700 sq ft.
Current HVAC is a 1.5 ton heat pump that heats/cools 700 sq ft but will be way too small for an additional 700.
I would like to find a way to incorporate a new home office and a wet bar into my design. I am also looking to plan for about 8 seats in the theater with a back row that is a bar top with barstools.
I think I can do at least a 9' ceiling as this area has about 20' to the peak of my roofline up there.
In the next few months I hope to finalize the design and start framing. Currently the unfinished area is floored with 3/4" OSB.
I have made a very rough floor plan design and pdf'd it. I dont know what is the best way to insert that into my thread.
I am looking for ideas on the good/better/best way to isolate most of the sound in the theater. I'm not concerned about sound going out the of the ceiling as that will be floored attic above it. I mostly want to minimize the boomy bass that carries downstairs.
Some of the challenges I have are that my current breaker box is at capacity, I do not currently have a chase to run new electric down to where my box is located. I know I am in the infancy of my project but since I am in no rush I want to make sure I think through all the scenarios and get this as right as possible since I am starting with a completely blank slate. I will post pics of the area this weekend.
I'm excited to start but a bit overwhelmed at the same time. I can't believe the dream might finally come true!
Here are the facts:
And the outlet is exactly 3 feet from the main panel on the same wall.
But that's mostly because I've sloppily added more and more stuff, without regard to what's on which circuit or adding additional power strips to group the low draw items (ethernet switch, IR receiver, external hard drive, etc.). Two circuits is nice to have, so you can dedicate one to high draw power amps, should you go down that road (subs).
