Check out this quick video http://www.youtube.com/watch?v=rnAaqy7mRLQ
I have seen post after post, of members recommending that the only correct setting for sharpness is 0/OFF. Then when someone says that their display then looks "fuzzy or out of focus" at 0, they are told that "you'll get used to it" and "it's the correct way to watch digital TV." The video above clearly demonstrates what can happen when the sharpness control is set incorrectly, and yes, incorrectly does include 0/OFF.
On my Samsung 60" 6420 LED/LCD, all ringing disappears around 12-18. At 19 on up, I can see a little ringing, but it only gets really bad around 60 on up (0-100). At 11 or below the image gets noticeably too soft or out of focus. I settled on 15 as it balances both issues perfectly.
Anyway, I'm sure there will be some posters that still hang onto "turning it to 0 is the only correct setting" and that the TV in the video "must be defective" and that's fine, but if you have turned your sharpness control down too far on the advice of many, and you think it doesn't look right, well you're correct, it doesn't look right!
Bring it on!!
Bring it on!!
