AVS › AVS Forum › Audio › DIY Speakers and Subs › RSS390HO 6.5ft^3 20Hz
post #1 of 5
How does this look? Do I have the filters set properly in WINISD for the Bash300? Thanks.
Should I be concerned with port noise?
post #2 of 5
You should change cone excursion to mm and air velocity to m/s.
Looks like you would need 2 4" ports, 23" long to keep port noise low.
post #3 of 5
Didn't think to change those. Thanks.
post #4 of 5
lowarkany progress on the build?
post #5 of 5
Good question about the filters. I'd like to know the same thing (is it set right?)
