sq area/coverage is a key factor with porous LF absorbers - and you do not have much coverage with two small superchunks.
also, you want to generate the waterfall plot to see the LF modal ringing / LF decay times...
) I feel your pain brotha, and I cant stress enough how the proper combination will help you. One thing that might help in running your graphs is to not assum you can tame EVERYTHING with room treatment, you have the BFD and audyssey after your preliminary eqing to also aid in your quest for a flat bass response. Try some filters on the BFD at the 28hz and 60hz peaks to pull those down a shade and see what you think. Dont quit on the room treatment stuff either! Just give some other things a tweak and see where you get. Peaks are better than nulls IMO so go after those and redo your waterfalls and whatnot, see if they clean up a little
Ill be following your thread closely and will continue to post any findings I have in the same search for "better bass up front"
