Hi,
I need to move my ethernet home run to another room in the house. My current home run is a two gang plate with 12 ethernet ports that I installed myself. This is a pretty half-ass way to do it. I need to to it "right", and want a real patch panel. This is of course an existing room, so I'll be cutting drywall, etc.
I think 12 ports will be plenty, as I typically only need on drop to each room. My house is not that big. I see some panels like this
, should I be considering something better?
Also, I'm having a tough time deciding on going with a 5e vs. 6 setup. I understand connections, cable, and patch panel has to all be Cat6 for it to get the full benefit of Cat6. The longest runs will be <100ft, and I'm pushing IPTV, streaming music and video throughout the house. I have Cat5e now, with no issues.
Tips and suggestions are definitely appreciated.
It's on an outside wall, with no attic above, and of course located between two studs. I realize I could cut out dry wall and go horizontally a few feet over through some studs, but I consider that major work/repair, so it's out of the question for me
Even if I found a closet to stick some of this stuff in, I would be concerned about ventilation.
