Okay I need some help. I am trying to plan out my basement build. None of the gray/white walls have been built and the green walls are just and idea I had if I went with Placement B. I only have about 900 sq. feet to work with, but I want to have a office/bedroom, bathroom, utilities area, and a room for a theater and exercise equipment. I didn't want to break up the theater and exercise area, because I am afraid it would make the rooms feel to small and would limit the use or options down the road. So far this is what I have come up with. The 2 post down the middle of the house add more obstacles and limitations. The way I see it I have 2 options for the theater section, neither are ideal, Placement A and B. Initially I was leaning towards Placement B, but after I drew in the Dolby recommended location lines, the lines jetting out of the couch, I notice that pole behind the couch would block the rear right speaker.
Could you guys tell me which placement you would go or improvements to the layout? Also, I am trying to figure out what type of speakers would work best for the side and rear surrounds. In-wall, on wall, ceiling, mono pole, dipole, bipole, etc...
If it matters, so far I stumbled on to good deals on a Panasonic PT-AE7000U projector and a 100" Steward Studiotek 130 screen, so that is what I will be using for the projection.
Topp
Topp
