Hi Guys...
I'm pretty new to HTPCs but have been doing a lot of reading and am very interested in setting one up to replace my cable box. Because i still need cable (mostly for live sports) I wont be cutting the chord, but it will replace the STB. I have a few questions and again, please bare with me... some of these questions might seem stupid.
1) Based on what i've read there are two options that i would consider since i need to use cableCARD the Ceton or the SD HDHR Prime. For the HDHR it seems I can just hook it up to the network and multiple machines can use it to tune to the TV network, as for the Ceton i need to have it installed in PC which is always on in order for other TVs in the house to be able to tune to cable... Is my understanding correct? I think i'd pick the HDHR for sure in this case...
2) If i want to replace the STBs in two rooms, do i need to build HTPCs for both rooms? I couldn't really figure out what exactly is a MCE (i know the xBox serves as an MCE) other than that it allows for me to stream media off of a network device... Can someone clarify this for me? Most my TVs do that with DLNA already so I'm not sure if this is the same or not. I would like to control all of my devices using iRule and if i want to do it over IP then I'm guessing i need to build HTPCs for each TV?
3) Does the HTPC DVR shows to the NAS or to the local drive?
Well i'm sure this is just the start of many questions im going to have... thanks so much for your help. Great community here.
