I have a Sony Bravia KDL-52XBR4 TV. (Mfg. Jan2008) It took a fall and landed on it's bottom edge. It works but now the right side of the screen seems to have a delayed action causing a "trails" effect not unlike the Windows mouse effect on PCs.
I am thinking that the two right side inverter board could be damaged? I checked all connections that are accessible with the rear cover removed and reseated the two left inverter boards.
Any advice if the two inverter boars I ordered on e-by do not fix the problem?
Thank you,
Joe
Thank you,
Joe
