AVS › AVS Forum › AVS Forum Information › Forum Operations Center › martiniadnetwork hangs
post #1 of 2
Just a note to let you know that something called the martiniadnetwork hangs your system quite often. The workaround is to stop the page from loading then retry it. Not serious, but a pain.
post #2 of 2
I'm not seeing anything like that, but a quick Google search will take you to their opt out if that helps...
http://www.martinimediainc.com/src/opt-out.html
  Back to Forum: Forum Operations Center
