AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › The *OFFICIAL* 2012 Toshiba L6200U/L7200U Passive-3D Owner's Thread...
The *OFFICIAL* 2012 Toshiba L6200U/L7200U Passive-3D Owner's Thread... - Page 8
post #211 of 367
Originally Posted by kfox203 View Post
Anyone find it odd that the reviewer's 'calibrated' settings have the backlight cranked to the limit of 100, same for contrast?
http://www.televisioninfo.com/content/Toshiba-47L7200U-LCD-HDTV-Review/Calibration.htm
Makes me question the whole review.
Yuuup!!, never tried them settings tho
post #212 of 367
New software version released yesterday. 0.8.2 (?). Now flash is supported. biggrin.gif
I don't know what else is implemented.
Good! My one complaint now gone!
Earlier the sound (audessey option) wasn't doing much. Looks like it is fixed as well in this upgrade. Sound has improved and better.
The Picture Quality was very good even before. Hence for me 55L6200 has overcome both deficiencies & hence it is pretty good !
Edited by jilla60 - 8/24/12 at 9:10am
post #213 of 367
just got the update this morning i hate that there are no release notes...Called toshiba they dont know what the firmware contains, makes me wonder how people can get paid and still have a job without knowing about your own product...still love my tv tho
post #214 of 367
With the new software update, you can use (logitech) wireless mouse for web. biggrin.gif
post #215 of 367
Hey I was wondering if anyone else has problems watching 3D going from SBS to Top and bottom cause mine just gets stuck in the first setting i watched first...I have to power off the TV in order to change the screen format
post #216 of 367
Anyone else have a problem with this TV powering on? I have a new 42L6200U, and when I come home from work, sometimes I have to unplug and replug the TV to get it to turn on. The remote's Power button won't work. The Power button on the side won't work. RIDICULOUS! I've had this TV for less than a week.
post #217 of 367
Nope, pretty sure you are the first one here on that i would exchange it
post #218 of 367
So of all you enthusiastic peoples, who wants to be the first to do an input lag with the l6200?
post #219 of 367
I could try that tomorrow but all i have to compare it with is my asus vg278h...Would that be ok with you if so let me know!
post #220 of 367
TV was working well until the latest fw update. Granted flash is working now and the tv is also much user friendly with external keyboard/mouse. However, I think the update just broke my 3d function. Both 2d-3d and the regular 3d function are no longer working. All I get is artifacts now whenever I try to use the 3d function. Anybody run into similar issues?
2012-09-01 02-24-37-716.jpg 904k .jpg file
2012-09-01 02-24-42-498.jpg 1022k .jpg file
post #221 of 367
^^^ got that once before updates. i just took of the tv and turned it back on. and it started to work
post #222 of 367
Yes, had that once from from the July update...You could always do a TV reset make, sure you know your picture settings tho
post #223 of 367
Yeah like Antix04 said, it went away after I turned it off for like 10 min and turn it back on again. Hopefully it's not something we may have to worry about down the road....Still pretty weird though.
post #224 of 367
Thanks HyperC,
The asus vg278h seems to have only 0 to 5 ms of input lag and only 2ms response time, so that is very low:
http://3dvision-blog.com/6335-review-of-the-27-inch-asus-vg278h-3d-vision-ready-lcd-monitor/
Anyway, yes, that would be a very interesting input lag test indeed and should be able point out whether it does 30 ms or 16 ms for example.
post #225 of 367
Thanks HyperC,
Umm, ran into a problem noticed tv doesnt have vga or dvi so gonna have to get a longer hdmi cable
post #226 of 367
Ok, have you been able to find the longer hdmi cable yet?
post #227 of 367
No I didnt but i pretty much moved around everything to do it...Would not go 120hz dunno why and i tested the tv on hdmi 2...Seems weird took the photos with my gs3
post #228 of 367
post #229 of 367
Actually it doesn't. The Monitor is going way ahead of the TV. Im seeing the TV lagging by 50 and 70 ms behind.
post #230 of 367
Did you test in game mode, or pc mode? Did you turn off all possible processing, such as motion enhancements and 120hz?
post #231 of 367
Nope as I stated the test was done just on hdmi 2..Only thing i tried was getting it into 120hz and it didnt so i ran the test
post #232 of 367
Is there a change that you could repeat the test in game mode? It should make a huge difference.
post #233 of 367
Not really but i suppose if its really that big of a deal for you to know ...But there is a catch could you get me the information how to enter menu service menu biggrin.gif
FYI I tried game mode and PC vga all seem the same as first test 30ms
Edited by HyperC - 9/19/12 at 6:30pm
post #234 of 367
Just got this TV and trying to setup Netflix. I go to Smart Apps -> Netflix and it gives me a really long number:
TSB-USTV130000000000000000015264
I changed the digits around but it's that long.
I go to Netflix.com but the entry box isn't nearly that long, doesn't accept it and I'm not sure if I'm doing this correctly?
post #235 of 367
Do you have NETFLIX account? If not use a computer & create one. Then on TV, say "YES" to existing NETFLIX customer and should be able to sign on using email & password.
Always set an online account using a computer. Although these TVs are called SMART, they are still really idiot boxes biggrin.gif
post #236 of 367
I do have an account but it had a prompt after I selected Netflix. I haven't entered an email/pass yet. Let me try again and take pictures/notes.
post #237 of 367
Nevermind, figured it out! Any other good TV settings? I haven't seen many.
post #238 of 367
I hear ya, was waiting for cnet to do a review on it but they only did the 7200 you could try mine if you would like
Standard mode
Backlight : 54
Contrast : 95
Brightness 5
Color 6
Tint 0
Sharpness 8
Advanced Picture settings
Colormaster ON
ColorTemp 5
Dnyalight HIGH
Dnyamic Contrast 5
Static gamma 5
Noise Reduction Both LOW
Edge Enhancer +5
And thats as far as i gotten
post #239 of 367
Standard mode
Backlight : 54
Contrast : 95
Brightness 5
Color 6
Tint 0
Sharpness 8
Colormaster ON
ColorTemp 5
Dnyalight HIGH
Dnyamic Contrast 5
Static gamma 5
Edge Enhancer +5
I haven't checked but do you have to do anything to get into the Advanced Picture settings?
post #240 of 367
Yes highlight it and click OK
