in january i bought 6 polk audio monitor 40 series 2 speakers and a CS1 series 2 speaker for a 7.1 or 7.2 setup. still undecided on 2 subs or one, and had been planning on buying the onkyo TX-NR609 receiver to power them but the place i was going to buy it from ran out and dont have any more, the reason that affects what i am buying is because i have credit through them and would have been easier to pay off over time instead of all at once with current situation. now if i have to spend the money all at once just want the best receiver for the money. my price range is about $400 can go up to $500 if i must for a noticeable difference, would like it to have and easy to use on screen setup, auto calibration because the shape of the room is odd and not sure yet how i will have the speakers place might be a little funky, would also like about 100rms per channel power since the speakers run up to 125 and would like to be as close as possible to that number dont want to under power them. will be used with my pc for gaming movies music, i was told to run hdmi from GPU to the receiver for best sound instead card would like to make sure that is true
? have been looking at denon onkyo pioneer and yamaha but dont know any of the differences in features and components used by the companies.
thanks in advance for any and all help
also if there are any 2 subs for about 200 each of 1 sub for 400 you guys recommend above others i would love to hear about it
had been looking at 2 polk audio psw110's
? have been looking at denon onkyo pioneer and yamaha but dont know any of the differences in features and components used by the companies.thanks in advance for any and all help
