AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › First VT50 review
First VT50 review
post #1 of 284
AVforums have posted the first review i've seen of the panasonic vt50, here it is. The black level was too low to accurately test with their equipment on a full black screen, but with ANSI it measured 0.0095 cd/m2
http://www.avforums.com/reviews/Pana...82/Review.html
post #2 of 284
Av penthouse letters:
The black is so deep, in fact, we couldn't get anything like an accurate reading with a full black pattern on screen but we did manage to measure it at 0.0095 cd/m2 on an ANSI checkerboard
post #3 of 284
Does this mean they are even better than Kuro Blacks?
post #4 of 284
that measurement sounds way high
post #5 of 284
I mean I guess compared to a 500m Kuro, but i'll take .0095 cd/m2 ANSI any day of the week
post #6 of 284
I still say next year is the year the Panasonic VT series will overcome the Kuro as the best tv ever.
post #7 of 284
That's not high at all... I think you're mistaking cdm2 (Candelas per Square Meter) with foot lamberts. 0.0095 cdm2 is 0.00277fL, which is a bit lower than what they measured the ST50 (ANSI 0.011 cdm2 / 0.0032fL). It's not 9G kuro blacks, but it's pretty damn good. Expect the 60+ models to be even lower. This is about what I expected from the VT50. The ST50 is much lower than I was expecting, making it an incredible value.
post #8 of 284
O man, this is sweet news. I may replace my 50 inch Kuros for bigger sizes and this may do it.
post #9 of 284
Originally Posted by rahzel View Post
That's not high at all... I think you're mistaking cdm2 (Candelas per Square Meter) with foot lamberts. 0.0095 cdm2 is 0.00277fL, which is a bit lower than what they measured for the ST50 (ANSI 0.011 cdm2 / 0.0032fL). Expect the 60+ models to be even lower. This is about what I expected from the VT50. The ST50 is much lower than I was expecting, making it an incredible value.
How is that reference blacks? Kuro is 0.001 and 0.0004. And isn't 277 higher than 32?
I never truly understood how these ftl numbers work.
post #10 of 284
it's .00277 to .0032, the former just has extra precision, comparing apples to apples it's 27 to 32
post #11 of 284
Why does it have to match a 9G Kuro to be "reference"? Anyone expecting the VT50 to match the 9G Kuro was setting their expectations too high. The VT50's mll was too low for their meter to read, so it must be extremely dark, and the ANSI black measurement is VERY good.
edit: For reference, to convert cdm2 to ftL, divide cdm2 by 3.426, or multiply ftL by 3.426 to get cdm2.
And as karl said, it's 27 vs 32. Rounded up, it's 0.0028 vs 0.0032.
post #12 of 284
agreed
post #13 of 284
I want to save my pennies for it but the false contouring makes me think I should just settle with an st50. Sounds like a great panel.
post #14 of 284
The correct comparison would seem to be VT50 vs. VT30, and it seems that the VT50 is a worthy upgrade at this point.
post #15 of 284
Oh i see. Thanks.
Well if the kuro has reference blacks how is anything higher.....reference?
I must be the only fool, but i was expecting the VT50 to be as dark as the 9Gs. 70" too.
post #16 of 284
The 9G Kuro isn't used as the benchmark for reference blacks, it just has reference blacks, too. You'll have to ask AVForums what measurement is considered "reference".
Considering the small steps Panasonic has made in past years, you shouldn't have expected them to match the 9G Kuro in a single year. Personally, I feel Panasonic has done a great job up and down the lineup this year, in terms of both performance and aesthetics... the 2012 line are very solid TVs.
post #17 of 284
Just keep in mind that the model reviewed was a 50". It might not give an accurate account of what to expect with a North American 55 or 65".
post #18 of 284
That's right, hopefully the black levels will be even be lower for the bigger North American versions .
p.s. I see you live in New Zealand, consider me ridiculously jealous. Can't wait to vacation there sometime in the near future.
post #19 of 284
Don't be jealous. We'll probably get a 50" VT in a couple of months, the 65" in September, no 55" at all and we'll pay four times as much for them as you do.
Oh wait, you were jealous over the other stuff we have. Never mind then.
post #20 of 284
Not to go too OT, but this quote caught my eye. All I could do is *nod* on my end.
" ...and the fact the market has driven prices down for large flat panel displays to the extent where they’re forced to use wide tolerance components and it begins to look like a big ask. Not to mention that now, more than ever, they also need to consider the aesthetics of their products more carefully and so have to cram the innards in to as thin a chassis as is possible. "
My 2006 LCD blows away any of the 2011 LCDs out of the water in terms of raw PQ. So sad...
post #21 of 284
Your 2006 LCD blows away a sharp elite in raw PQ? I think you're confused.
post #22 of 284
So glad I passed up the VT30 and waited for this!
post #23 of 284
Can't wait to see this at the shootout
post #24 of 284
wait, so the st50 is .0032 and the vt50 is only .0004 lower at .0028.
That actually disappointing the vt50 barely improves on the st50. Whats the point of spending a ton extra on the vt50 then.
post #25 of 284
Those are the ANSI black level measurements (checkerboard pattern measurement) which is typically higher than the MLL (minimum luminance level... measurement at a black screen, or 0IRE). They measured the EU ST50 at around 0.0023fL @ 0IRE and they claim that the VT50 was too low to take a measurement. D-Nice commented about their MLL reading of the VT50 at the 'other' site and said that can't be right, because the meter they used can measure accurately down to 0.0003fL, and there's no way that the MLL of the VT50 is that low.
So with that said, I would wait for a technical review of the NA VT50 before we make conclusions on the VT50's MLL measurement. My guess is that the MLL for the VT50 will be around 0.002fL (D-Nice's latest measurement for the ST50 was 0.0028fL) for the smaller sizes, and a little lower for the larger sizes.
As for what the VT50 offers over the ST50, the VT50 has other features, like more picture adjustments (which will allow you to tighten up the picture a little) and 96Hz mode for 24p sources, and a sleeker design. The ST50 is definitely the far better value, though. As is the case with all consumer electronics, the more you spend, the margin of gain becomes smaller.
post #26 of 284
lookin more and more like im gonna have to keep my un55b8500 another year. I hope the NA models pull off a miracle
post #27 of 284
Sorry, I probably should have been clear and stated (with the exception of LCD TVs that cost >$4k )
post #28 of 284
If the ST (and GT if I'm not mistaken) had the picture controls of the VT, I'd probably be OK with them. I'm an amateur calibrator and I need those controls to make that investment worthwhile. Other than forcing NA buyers like me to the VT model, I don't quite understand why the UK models get these controls, but we don't in the states.
post #29 of 284
Reference black = 0 cd/m^2, so they are using the term poorly. They should have been able to measure a full black with the equipment they had so either they screwed up the measurement or the panel shuts off with a full black input.
post #30 of 284
With the strict energy guidelines set for tvs it may be a while before anyone matches Kuro blacks?
