AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › Scored me a Panamorph!
post #1 of 5
Might be accumulating things in the wrong order but... I bought a new in box Panamorph UH380 with the motorized sled and remote! This is a re-branded Optoma unit, which might have helped getting it for a fairly reasonable price. Nobody else apparently knew about the re-branding. Can't wait to get it, although I don't know why. The room is far from done and the projector isn't even bought yet! I guess I can hold and look at it.....my precious.....
This weekend the stage and screen wall are slated for construction.
post #2 of 5
Nothing wrong with getting the A-Lens first. If anything, it keeps you focused on the end result.
post #3 of 5
congrats, I've got a UH380 via b-stock from avs here, very happy with it.
Mines on manual DIY sled, lucky you to have a motorized sled.
You know that means you need motorized masking to go along with it
Manual masking just won't match.
post #4 of 5
I know! I was just going to make masking panels but am now looking into the components and engineering a possible motorized masking setup. Since I am going to be building my own AT screen, I guess making a motorized mask might be doable. Don't know yet.
post #5 of 5
Moggie is the champ of DIY screen with masking. You may want to check out this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1295320
