AVS › AVS Forum › Other Areas of Interest › Camcorders › Better video quality: DSLR or Mirrorless Camera?
post #1 of 5
Hi there, I was just wondering which type of camera shoots higher quality video, DSLR or mirror-less "compact system" cameras? Thanks!!
post #2 of 5
I found these Olympus OM-D E-M5 (mirrorless) videos while browsing YouTube. They look sharper, brighter and with more vivid colors than my Canon Rebel T3i (DSLR).
http://www.youtube.com/watch?v=jeazsEx_DU4
http://www.youtube.com/watch?v=AnNA7lH3knU
post #3 of 5
eric - you will find fabulous video shot with either type of camera. Either can produce great video images (I have owned both the Canon T2i DSLR and the mirrorless (I call them DSLMs) Panasonic GH2).
Some great examples of Canon T2i (DSLR) video:
Even Wedding: http://vimeo.com/26518622
Spring and the Dancer (music and dance): http://vimeo.com/10379801
The Camera (narrative): http://vimeo.com/32655795
Marilyn (narrative): http://vimeo.com/24012195
Some great examples of Panasonic GH2 (DSLM) video:
Beauty Queen + Bee Keeper (wedding): http://vimeo.com/37401106
I or Me (narrative): http://vimeo.com/19410230
Dust in the Wind (narrative): http://vimeo.com/30051081
I'm So Sorry to Hear About Henry (narrative): http://vimeo.com/38908439
Although these are terrific examples of what can be done with the cameras - it's more important to determine whether the balance between the capabilities and the limitations of a camera meets your individual needs.
My Canon T2i, for example, was a great video capable still camera (great colors out of the box), but I personally could not live with its limitations in video mode (12 minute maximum clip length, blank viewfinder, no autofocus, and horrible moire on colored fabics and complex patterns such as shingled roofs). So I bought another great video-capable still camera, the mirrorless Panasonic GH2. For me, its video capabilities (incredibly detailed resolution for the price) far outweigh its (mostly ergonomic) limitations.
Hope this is helpful,
Bill
Hybrid Camera Revolution
Seeking the still/video singularity
post #4 of 5
Hi, all, new around here, and very much a tyro when it comes to video, even if I've fooled around with it for a while!
Planning a trip abroad, I came to think of which camera to use for video. As I happen to have access to quite a few cameras, the choice wasn't a foregone conclusion, so I decided to investigate:
Recently (Yesterday) I did a very non-scientific test (a pan around the living room, with some view of the surrounding houses), with some of my (and my wife's) cameras, and our single camcorder (Canon HF10), as to their usuablity as video recorders (I avoided my (D)SLR(s), as they will be used are used for other kinds of capture).
They cameras were, in no particular order:
Sony NEX-5N
Sony DSC-TX5
Sony HX-9V
Olympus XZ-1
Nikon V1
and the affore-mentioned Canon HF10
Lighting conditions were OK, overcast outside, and all lamps available on -
on extra lighting, just normal.
The ZX-1 was bright, but of low resolution, and didn't like panning, thus last.
The DSC-TX5 has a very small sensor, thus suffered some from the lighting conditions, otherwise OK.
The HX-9V is brilliant in good lighting, thus not at its optional best here.
Then came the V1, which with a suitable lens is very capable (the kit lenses are not very fast, but you can, with the TF1 adapter use any 'normal' Nikon G lens).
Best was the NEX-5N, as expected, but it needed a little positive exposure compensation (which you can do while 'filming', hurrah!). The kit lenses have mostly anti-shake, but I used the Zeiss-branded 1.8/24, which does not!
My wife has the excellent E18-200 lens for her NEX, which is superb for video, as it was designed with video in mind.
Sadly, the NEX-5N is known to be prone to overheating after a few minutes of recording, when used in video mode (just as its big brother, the NEX-7).
Movie quality with the NEX-5N was slightly beyond the HF10, but as with the V1 it all depends on which lens you use! the V1 is not known for any overheating problems, by the way!
Hopefully my wife's up and coming Olympus OM-D will outshine all these cameras/cams, but only time will tell ;-)!
If noise is a factor I'd avoid DSLRs, and the NEX, as their shutters are very audible (the XZ-1 inside a UW housing is equally silent). The V1, the 9V, and the HF10 are better choices then!
As yet, in good lighting conditions I'll settle for the 9V, for the rest I'll use the HF10!
Will redo the test later, with the three best, plus a Pentax, or two ;-)! And the OM-D, if it has arrived by then!
post #5 of 5
Originally Posted by Tord S Eriksson View Post
......The HX-9V is brilliant in good lighting, thus not at its optional best here....
As yet, in good lighting conditions I'll settle for the 9V, .....
I confess to being a HX9V "fan boy". As it pertains to OP's question, it is compact and mirror-less.
I taped a small led "pocket flashlight" to my HX9V to shoot a Halloween haunted house. The house lights were out and the walls lined with black sheets. Other than a few "mood lights", it was very dark. There was a mist machine that made it hazy. The light is terrible, but the camera worked.
http://www.youtube.com/watch?v=fEVLuX-6Bt0
And another that I shot in awkward light: http://www.youtube.com/watch?v=ckxG1qFQVCU
The performance of the HX9V in bad lighting may not be as brilliant as in good light, but I think it can still be expected to get usable shots.
Bill
  Back to Forum: Camcorders
