AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › New house, living room setup!
post #1 of 20
My humble setup:
Cable management really was a challenge since the walls are all concrete.
Update 3/31/2012
samsung PN59D550
Yamaha RX-V1800
samsung BD-E5900
Xbox360
Yamaha NS series:
NS-555
NS-C444
NS-333
YST-SW315
post #2 of 20
Nice HT, very clean.
post #3 of 20
Super clean look, Simple and elegant well done.
post #4 of 20
Originally Posted by SAVholic View Post
My humble setup:
samsung PN59D550
Yamaha RX-V1800
samsung BD-E5900
Xbox360
Yamaha NS series:
NS-555
NS-C444
NS-333
YST-SW315
I like it, we have similar tastes!
post #5 of 20
Now that's clean! Have you tried angling your rears a little more towards the mlp?
post #6 of 20
Thanks for the reply!
The next step is to add a black/white(finally convince the wife) rug and maybe some accent pillows.
post #7 of 20
I move them a couple of inches, It looks almost the same but they are more directional from were we sit. thanks for the input!
post #8 of 20
Great yamy setup and your room is clean and beautiful, congrats!
post #9 of 20
I like the cabinet with shiny sheen gloss look and front wall orange or is that terracotta? I like the floor clean look do you use a mop or vacuum cleaner or a little bit of both?
Clean simple all-around homey place you have.
post #10 of 20
Very organized and well done setup. That looks like the same color of paint I used in my theater.
post #11 of 20
Thanks! I looked at your setup as well, very nice!!
The color is actually "chili pepper". We use a mop and then a dry mop so the tile is streak free. I'll try to post some pics after we add the rug.
Thank you! The speakers really deliver a clean and transparent sound.
post #12 of 20
Updated the first post. Added the rug today
post #13 of 20
Super nice clean setup. Area rug is awesome. The color really ties everything together. Is it comfortable to walk barefoot on? Where did you buy your area rug??
post #14 of 20
Very nice and clean. Always had a soft spot of the NS, I think they look great.
Nice camera work too
cheers
post #15 of 20
Thanks! and yes the rug is very comfy to walk barefoot and I got it at a local furniture store called "Paos"
cheers
Thanks!... the next step is to replace the sub with a gloss black SB12-NSD or dual SB12's
post #16 of 20
Very clean!! I need to know how you hid the wires!? Did you try the Ns-333 as mains? Impressions?
post #17 of 20
Thank you! Well for the wires, I had my contractor put a 2" PVC tube on the wall before it was plaster with concrete and for the surrounds I bought some wire covers with self adhesive at home depot and paint it. I haven't test the NS-333's as mains yet but I think they're very capable, I would recommend a good sub crossed at ~ 90/100hz as they don't go as low as the 555's.
post #18 of 20
those tables really ROCK
seriously though, great setup. I dig the wall of color, and the photography skills!
post #19 of 20
post #20 of 20
I'll update the first post later and fix the image problem but for now this is the latest addition to my system: dual JBL's ES250BK. They sound way better than expected....
