I want to use my FIOS HD cable box in my bedroom to also run a TV on my deck. I will not be watching both tvs at the same time so I don't mind if the channel is changed on the deck.
My plan was to purchase http://www.monoprice.com/products/pr...seq=1&format=2
I would hook the BR TV with HDMI out and the deck tv with the cat 6 cable.
1) Would this setup work or is their another recommended alternative?
2) Would the cable remote work on the deck to control the cable box in the br?
3) could the cat 6 cable be terminated with a keystone and a cat 6 path cable used to continue to the adapter that converts the signal back to hdmi. Or does the cat 6 cable run have to be uninterrupted.
4) How to protect the equipment from the weather (enclosures?)
