AVS › AVS Forum › Audio › Receivers, Amps, and Processors › High end receiver, help me pick! Buying SOON!
post #1 of 11
Hello
I'm getting a new high end receiver today or tomorrow and I just need some help deciding which one to get. I live in Sweden and my main alternatives right now are in the poll above.
I'm not sure if its worth getting the 3010 over the 2010, but if you do think it is, please tell me why.
The LX75 is an european model, I'm not sure if you have a similar one in the US.
post #2 of 11
denon 4311...
post #3 of 11
Originally Posted by ccotenj View Post
denon 4311...
It would be an option if it wasn't so expensive here in Sweden. It costs over 2500usd while the other options are ~1800usd.
post #4 of 11
I would suggest a denon receiver, but since neither of my AVR-5805s are working for the moment, I cannot hear how they sound so I cannot recommend their awesomeness, nor any other denon AV receiver.
However, I think you should seriously consider the Denons
post #5 of 11
We only have the 3312 and 4311 in Sweden. The 3312 is below the ones I've listed, and the 4311 is too expensive..
Otherwise I would go for the 4311!
post #6 of 11
Anthem MRX 700. You don't have to buy it; my suggestion is to listen to it before buying anyone of those on your list.
post #7 of 11
3500usd+, a bit too much.
Unfortunately no shop nearby has them for demo, but I have a free of charge return policy within the first 10 days so it's OK.
post #8 of 11
Then demo it. There is a 300 and 500 as well. $999-2000.
post #9 of 11
All of those who selected "other", which models are you referring to?
post #10 of 11
I will bet Denon.
post #11 of 11
Originally Posted by oztech View Post
I will bet Denon.
Yeah well unfortunately not an option as of right now... Too expensive. How does the SC-LX75 and RX-A3010 compare to the Denon? Also, how do they compare to each other? I can't decide between the two.
