AVS › AVS Forum › Video Components › Home Theater Computers › Advice on a SAS Expansion Card for My Build.
post #1 of 6
I am upgrading my media server. I am moving away from my hardware RAID 5 setup and going to FlexRaid. I just purchased a Norco 4224 case to replace my old case. Since the backplane in the case uses SFF-8087 connectors, I am looking for some affordable cards with SFF-8087 connectors on them.
Any recommendations?
post #2 of 6
I am using two rocketraid 2680 pcie cards, in a Norco 4220 box with 4 sas cables to the backplanes on W7x64 and Flexraid snapshot raid with pooling. I currently have about 13tb in the box with plenty of room for expansion. It has worked well for me and the cards are available on Newegg for $99
post #3 of 6
I would recommend two of these.
You would also need forward breatkout cables. Also make sure your MB supports 2x at least x4 PCI-e slots.
post #4 of 6
Correct me if I am wrong but I will not need the breakout cables since the Norco 4224 uses an SFF-8087 connector on the backplane. I would also need three of these cards (if I wanted to max out the HDs) since I have 6 backplanes in the Norco 4224, correct? Each port on the card going to each backplane in the case.
post #5 of 6
Originally Posted by lars99 View Post
i would recommend two of these.
+1
post #6 of 6
You still have SATA ports on the MB.
Probably easier to explain with pictures. Here's a guy who did an unRaid build using that case and a complete parts/pictures list. Hope this helps.
http://lime-technology.com/forum/ind...?topic=12822.0
