AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Harmony One & Dish Network Question
post #1 of 3
A friend picked up the HO but cannot get it to work with Dish Network. Are there commonly know problems between the two?
post #2 of 3
On the Hopper/Joey/922 make sure IR is enabled. On others make sure receiver address is set to 1. Confirm those settings, and any universal remote will work fine.
post #3 of 3
Thanks. I've never had cable so thanks for pointing me in the right direction.
  Back to Forum: Remote Control Area
