AVS › AVS Forum › Audio › Audio theory, Setup and Chat › HK AVR 158 auto detect problem
post #1 of 4
Hello,
My Harman Kardon AVR 158 receiver is conected to my computer with optical SPDIF cable.
The receiver able to detect DTS and Dolby Digital just fine, but my problem is when i pause the movie the Display on the receiver change from DTS/DD to PCM and when i play the movie again it change back to DTS/DD.
Each time there is such change there is a sound of electrical power surges from the speakers.
It looks like that signal is changing when pausing the movie.
Can someone please advise how i should fix it? Is there any special set up i should do?
I have windows XP with on board sound card.
I will appreciate your help as this is driving my crazy.
Thank you
post #2 of 4
Engage "mute" on the AVR before pausing the movie. Turn "mute" off on the AVR when the movie has been restrarted.
post #3 of 4
Thank you Ratman.
I was thinking that there would be other solution for that.
I did a small research and apparently this issue is very common as "spdif pause bug", but i didn't find any solution that works.
If someone know how to fix this problem i am sure it will help others as well.
post #4 of 4
bonjour je voudrai savoir comment avoir le son de ma tele sur mon ampli mad.gif
