AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Looking for Panasonic 50" Plasma TV Pedestal stand (2008 model)
post #1 of 6
I have a 2008 model Panasonic 50" Plasma HDTV - TH-50PZ85U. The TV has been mounted on the wall above the fireplace in my current home for the last 4 years but I'm moving and will be placing on the stand instead.
I have the black stand but do NOT have the hardware that I need.
I'm looking for the stand METAL POLES and SCREWS (8 total, 4 of each type) to mount the TV in the stand.
PM me or reply here if you have them and aren't using!!
post #2 of 6
Originally Posted by 99RedSi View Post
I have a 2008 model Panasonic 50" Plasma HDTV - TH-50PZ85U ... I'm looking for the stand METAL POLES and SCREWS (8 total, 4 of each type) to mount the TV in the stand.
The pole part numbers are:
TBLA3615 STAND POLE LEFT
TBLA3614 STAND POLE RIGHT
And are used in the following models:
Panasonic TH42PX80U
Panasonic TH42PZ80Q
Panasonic TH-42PZ80U
Panasonic TH46PZ800U
Panasonic TH-46PZ80U
Panasonic TH-46PZ850U
Panasonic TH-50PE8U
Panasonic TH50PZ800U
Panasonic TH-50PZ80Q
Panasonic TH-50PZ850U
Panasonic TH-50PZ85U
Panasonic THC42HD18
Panasonic TH-C50FD18
Panasonic TH-M50HD18
You can usually find a complete stand with the poles and screws on eBay for relatively cheap, similar to this one. Otherwise, the poles themselves seem to go for $30 individually at a parts store. The screws can usually be found at a hardware store.
post #3 of 6
Will the poles in the TXFBL01LFUU kit from Panny work, can anyone confirm?
They are a different part number from TBLA3615/TBLA3614 but they look IDENTICAL.
post #4 of 6
Will the poles in the TXFBL01LFUU kit from Panny work?
The TXFBL01LFUU is for a newer model, and although they appear the same, there might be small differences. They seem less expensive.
Please let us know if you try the newer model, and if it works. Posts seem to get lost quite frequently.
post #5 of 6
The poles may look identical, but if you had them in your hands a closer examination will reveal that there are subtle differences in teh length, shape, taper, and hole spacing and they are incompatible with the openings in your TV and could easily damage the TV's chassis if you attempt to insert them in the openings and put the TV's weight on them. Make sure you use the correct ones for your TV.
post #6 of 6
I am dealing with the same situation only for a PANASONIC TH-50PX80U
Perhaps they fit both models (not likely)
If you come up with a source please advise and I will do the same
