I finally getting ready for wall treatments for small 12'x18'x7.5" theater. I planning on 1" linacoustic for the entire front wall, and at ear height and below on the side and back walls. The upper back and side walls will get 1" worth of poly-batting to fill it out and all will be covered with some dazian epxo cloth fabric.
Whit this small theater I'll have some left over linacoustic from my 100" roll. Assuming I have enough, would this be a good material to use to make 17"x17"x24" super chunk bass traps in the front corners? I read most people are using OC 703 which I think has very similar acoustic properites as the linacoustic. It sounds like the 703 might be more rigid than the linacoustic though. I couldn't find a local dealer for the OC703 so I was hoping the linacoustic would be an acceptable substiute for the 703 for a corner trap.
Another option with the extra linacoustic could be to use 2" instead of 1" on the front wall? I think the bass traps would be more desirable though in the small room.
