AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Sony MDP-740D Problem Reading LD's
post #1 of 5
Hi Everyone
Just got e Sony MDP-740D Pal/NTSC Player, really nice player. But has a problem, when i insert the LD, it recognizes the LD, the display lights up and doesn't read the disc.
This Player was low used, should't be like that.
I have the possibility to buy a new laser pickup for it. Do you guys think that's the problem?
post #2 of 5
Unfortunately, the real problem here is that it's a Sony Laserdisc player. Mechanical breakdowns are par for the course.
post #3 of 5
Hi
Do you think it can be fixed?
post #4 of 5
Would probably cost you more to fix this one than to replace with a better Pioneer model.
post #5 of 5
Hi
What the player does is:
The laser and the motor work. If I insert a laserdisc, the motor starts and you can hear that the unit tries to focus. Then it stops, but the display shows "LD"
The unit has very little usage...Can that be a simple Laser cleaning?
  Back to Forum: DVD Players (Standard Def)
