AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Wire 4 ohm and 8 ohm speaker in series?
post #1 of 11
In my bathroom, I have a pair of 4 ohm (in the shower) and a pair of 8 ohm in ceiling speakers (above my sinks). The shower has a glass door to the ceiling, so I wanted to be able to listen stereo sound while at the sinks and while in the shower.
The 2 channel amp I plan on using has a minimum impedance of 4 ohms/channel (Sonos Connect:Amp).
It doesn't appear I can wire them in parallel, because the 8 ohm and 4 ohm load would lead to an impedance of 2.67 ohms/channel, and the minimum is 4.
Would I be able to wire it in series? I wasn't sure if there would be a problem combining speakers with different impedance? Any help would be appreciated.
In order to clarify, I would run a wire from the (+) terminal of my left channel to the (+) of the 4 ohm speaker, then from the (-) of the "left" 4 ohm to the (+) of the "left" 8 ohm speaker, then from the (-) of that speaker to the (-) terminal on the amp.
It is my understanding that this will create a 12 ohm impedance load. Would it make a difference if the speaker above the sink was a single stereo speaker instead of 2 mono speakers? Thanks!
post #2 of 11
Connect them in series. The only problem I see here is that 8 Ohm ones will sound louder than others. But since they are different speakers anyway, it may not be an issue.
post #3 of 11
Although the 8 ohm speaker will have twice the power, the efficiency of the speakers may alter the perceived loudness from one set compared to the other.
post #4 of 11
If for some reason there is a bothersome difference in loudness that can be attributed to the impedances, you could wire an 8ohm power resistor in parallel with the 8 ohm speaker, and then wire the 4 and 8 ohm speakers in series for a total 8 ohm load. You would lose efficiency as power is dissipated in the resistor (which would need to be appropriately sized and positioned), but your amplifier will have additional output at 8 ohm as compared to 12 ohm so end result may not be much lost.
A transformer (volume control) would be the better, more expensive, option. Chances are that for your application wiring them in series as is will work adequately.
post #5 of 11
Are you talking about a a variac type 'volume control' or a variable resistor?
post #6 of 11
I was thinking of transformer based wall mounted volume controls. Maybe I misspoke. I know there are many kinds, some transformerless, and maybe they just act as variable resistors.
post #7 of 11
LPADS are the classic speaker level controls. I have seen them up to 100 watt ratings. But just like the series resistor, they waste power.
post #8 of 11
My bad then.
post #9 of 11
No.
Impedance magnitude varies significantly with frequency. An "8 Ohm" speaker might have a low of 6 Ohms and a high of 60.
Voltage will divide across the two speakers in proportion to their impedance at a given frequency; so where one speaker hits a peak you'll get less output in the other speaker.
The 8 Ohm speakers may (if sensitivity was greater than 6dB below the 4 Ohm speakers) or may not (otherwise; an 86dB/2.83V/1 meter 8 Ohm speaker in series with a 92dB/2.83V/1 meter 4 Ohm speaker will play just as loud).
I'd do something other than wiring them in series (extra amplifier, transformer based volume controls, L-pad volume controls with the two loads wired in parallel, replace the 8 Ohm pair with ones matching the shower speakers and run them in series, replace the 4 Ohm speakers with ones matching the sink speakers and run them in parallel) most likely something that gave them each their own volume control accessible in the bathroom.
post #10 of 11
My bad then.
No, they make transformer types too. There are also TPADS but they don't maintain constant impedance.
post #11 of 11
I wouldn't sweat overhead bathroom speakers unless there was a major problem. How much critical listening can you do in the shower?
