Does anybody know of a good one I can use for both radio and TV reception? I'd like to hook up my radio to my TV antenna with an A/B switch/splitter, but the last time I ran a splitter off of my antenna it weakened the signal to TV to the point where it started freezing up/cutting out.
I saw a couple models online but they seem to be designed primarly for HDTV, not sure if they cover the radio frequencies as well? Also what amount of gain is acceptable? All the models I've seen have a fixed gain of around 12dB, should I be looking for one that is adjustable? How much gain is too much?
Different casing/framework on mine but the conductors look the same.
