Originally Posted by
pleibowitz
Hi, I made an earlier post concerning issues I'm having with these glasses. Btw, they're my 1st pair of 3D glasses so I don't have anything to compare them too. My televison the HX929 automatically switches Motionflow off when I engage the 3D feature however I'm still having issues with 3D image quality and was hoping that someone who has gone through this can provide me with a solution. My issues are the following: 1. The 3D image on the television screen can appear blurred. 2. The 3D image will constantly flicker on and then off. 3. There is a color shift in the picture if I tilt my head to either side. I also contacted Sony customer support but unfortunately they're not much help. Thanks for your time.
Make sure your glass is on, I had a hard time powering it on most of the time because of my large fingers and the awkward position IMO of the power button, sometimes I thought it's on but turns out it's not
Also the glass attracts fingerprints or smudges and sometimes it's not noticeable till I take it off and take a closer look and so I thought the picture is blurry
Also have you tried using it fully charge to see if the bluriness will go away? I don't think there's any 3D glasses out there that won't have a problem if you tilt your head but then again, I have not tried nor seen reviews of other 3D glass anyway but if there is one, I would be interested to hear about it.
