Hello guys,
I'm still confused before someone can answer below 2 questions for me,
1. DSD format is the biggest advantage for SACD, but looks like on the market now all the players need to convert DSD to PCM then D/A convert to analog. DSD can direct convert D/A to analog, isn't it?
2.If the first question answers YES, then SACD support 5.1Ch, but most high end SACD players on the market now only support 2ch analog out, like Marantz SA-11S2(i assume maybe at this price , 11S2 decode DSD to analog directly), and there are no DACs with HDMI input which can decode DSD at this moment, so is that means now I can only play SACD by these universal players which can play BD, DVD, SACD etc?
The confused part is if you want to use your high-end DAC, you have to convert DSD to PCM or don't use your DAC and use your universal players internal DAC to convert PCM (which is converted from DSD) to Multi-ch analog, I think what a real SACD player is decode DSD and directly convert to analog Multi-ch, is my understanding right?
