My CPU fan and power supply fan are running quiet on my inexpensive bedroom pc build. The htpc will be out in the open and not in a enclosed in a cabinet. Can someone recommend a cheap yet quiet 80mm case fan, or has anyone ever gone without a case fan with sucess?
What CPU and MB temps do i need to try to keep my PC at before I need to worry about frying something?
The htpc is a microatx, Asrock H61 mobo, with 220 watt psu, intel g620 w/ built in 2000 graphics & only a 60gb SSD-no pci slots in use. It is only used as a streaming PC, and only has win7 and a few other software on the SSD.
thanks!
What CPU and MB temps do i need to try to keep my PC at before I need to worry about frying something?The htpc is a microatx, Asrock H61 mobo, with 220 watt psu, intel g620 w/ built in 2000 graphics & only a 60gb SSD-no pci slots in use. It is only used as a streaming PC, and only has win7 and a few other software on the SSD.
thanks!
