Subject says it all, I'm wondering what the Pros and Cons are between a pair of sealed SubMersives or Captivators. Please advise, thanks.
BTW in case it matters, the subs will go into a 13'x23'x7' room (2,100 cu ft). Initially I'll get a single sub (SubMersive or Captivator S), then later when budget allows I'll acquire a second sub to balance any nulls or other issues in the room. Also, the theater will have corner bass traps and some acoustic wall panels installed shortly. The subs will be located behind an acoustically transparent projection screen / false wall.
As crazy as it seems, they have to make money too...........
