AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Thin/Flat Speaker wire for Surround Speakers?
post #1 of 7
I need to run speaker wire under an area rug for my surrounds. Going through the wall or baseboard isn't an option since it is a rental. Any suggestions? I know Nordost makes flat cable, but I am not spending $750 on surround cable.
post #2 of 7
I used some flat white cable ( I think I bought them from Best Buy) which has adhesive on one side. The cable is actually flat solid copper & not strands. It was expensive ( compared to monoprice) , but not $750 expensive
post #3 of 7
I think years ago I bought some flat speaker wire from RatShack.
Google "flat speaker wire." There are tons of hits for everything from fairly flat to superflat with an adhesive side. The prices I see are mostly reasonable depending on the length of your run (heck, even the MonsterCable flat wire for a short run doesn't break the bank), especially compared to the Nordost stuff. I don't know what "the cheapest" is as I haven't had a need for this kind of wire in a long time, nor do I know of the best source to buy it in bulk.
post #4 of 7
I've used this for my shakers in the couches.
Flat Wire from Parts Express 100ft
or shorter length:
Flat Wire 50ft
post #5 of 7
My under rug solution was based on 100 conductor computer ribbon cable. 50 fine gauge wires in parallel have the approximate copper content of 12 guage wiire.
I wired alternate strands into plus and minus, reducing inductance. I soldered ordinary 12 gauge speaker cable to the ends for ease of termination.
post #6 of 7
http://www.taperwire.com/
and
http://www.flatwireready.com/
I've used both with good results.
B.
post #7 of 7
I was going to recommend some Tributaries flat speaker wire, but it appears that they have discontinued the two types I was familiar with. They only carry a silver plated OF 14 awg flat type now (403 strand version). It runs about $2.50 a ft., so not cheap, but probably pretty good, and will experience very little loss over a long run. Only downside, if not running it under carpet, or through walls, is that it now uses a clear jacket, which might not be as attractive as their discontinued white jacket models. I'm using their old plain copper stuff, lol, that was maybe a wee bit cheaper, but which I love. Now that I know it is no longer made I'll have to really take care of it.
