AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Call of Duty: Black Ops 2
Call of Duty: Black Ops 2 - Page 42
post #1231 of 4670
Hmm never thought about the "Rambo" class one of equipping yourself with a bunch of perks etc and no weapon but picking up one off the ground.
Interesting idea for sure.
Greg
post #1232 of 4670
Greg
post #1233 of 4670
Originally Posted by vedderpj13 View Post
Exactly Buc, well said. My message to everyone was be patient, you might get super frustrated but over time you'll find a class that you love and do really well with.
For those interested, here is the class I really like playing...
100% correct with the hip fire stuff and the laser sight, it is unbelievable what a difference that thing makes. And as you can see I don't use any equipment, nor do I use a 2nd weapon. I will switch around attachments (laser sight stays every time though). I use these 3 the most, but will also use Fast Mag, Rapid Fire (BTW, this has some serious negatives to a couple areas on the gun rating), and Adjustable Stock.
Cool website. Has the gun ratings in numbers instead counting those damned dots! How Treyarch came up w/ dots over numbers we'll never know lol!
post #1234 of 4670
I'll pick up another weapon if I run out of ammo, or want to carry two. Your probably right though, could put something better up.
post #1235 of 4670
Does scavenger replenish equipments like EMP nades?
post #1236 of 4670
I'm liking some aspects of this game, but the footstep issue is just one I cant get past. Why in gods name, can I hear my teammates footsteps, a silencer being fired across the board, but I cant hear the enemies footsteps. Even with the awareness perk, footsteps are nearly impossible to hear. Therefore both the awareness, and dead silence perks are useless. To me, this makes players result to camping because there is 100 ways behind you in each board, and if you cant hear the enemy , nearly at all, to me they dropped the ball in this area. I saw a comment David Vondahaar made yesterday, he was asked about footsteps, and he said footsteps were too loud in Bo1, and they didnt want to give people an advantage that have headsets. So , to recap, If I have a good internet connection, I will be penalized with lag comp, and if I have a good surround unit, or headphones, I will be penalized for that. Just a rant, I tweeted him, and ask that he fix, if it annoys any others in this forum, shoot him a tweet, @DavidVonderhaar , maybe it gets patched.
post #1237 of 4670
Won't happen. Terminal is a Modern Warfare (i.e. Infinity Ward) map not a BLOPS (i.e. Treyarch) map.
I doubt you will see any other retreads from Blops by Treyarch.
While Blops maps were good I don't think there was a major fan favorite other than Nuketown except for maybe Jungle.
Greg
I wouldn't mind firing range.
post #1238 of 4670
I'll check his tweets to see what he said, if they didn't want to give people with headsets an advantage why didn't they just remove dead silence and awareness altogether? makes no sense at all.
post #1239 of 4670
Yep drop those perks completely or at least make them have an advantage to using them. As-is what's the point.
post #1240 of 4670
It replenishes my bouncing betty's and shock grenades, so I'd say yes.
There's a nice trick with scavenger where you drop your bouncing betty, pickup a scavenger pack, then pick your bouncing betty back up and you can carry 2. works with shock grenades too, so I'll run around with 2 of each most of the time.
post #1241 of 4670
How do you have time for all that. I feel like I get a kill, die, spawn, run, die spawn and repeat.
post #1242 of 4670
post #1243 of 4670
Scavenger is probably my favorite perk, don't really find most of the others that critical.
post #1244 of 4670
I too struggled at first, relative to my already meager ability.
Finally started to get it a groove.
Here are a couple of my better games.
This was with an MP7 and a speed class. As you can see, the KDR wasn't great, but I got over 5,000 points with all the confirms
This one I had an SMG primary with overkill and a SVU sniper eqipped with a silencer and Ballistic CPU. Good KDR, but not many confirms...
All in all, I'm really enjoying the game...
post #1245 of 4670
^^The same guy killed you 12 out of 13..wow. I'd have been pissed!! wink.gif
I wonder if you killed him just as bad/good...
post #1246 of 4670
For anyone questioning what happens when you prestige, I took these pics:
post #1247 of 4670
So you can reset your K/D? Am I reading that correctly Buc? Sorry, on phone.
post #1248 of 4670
If that's true, that's total BS. Nothing like punishing those that love your game the most to go out and spend $300 on a headset and equipment.
post #1249 of 4670
wat? You can have two shock grenades to start with. Are you only starting with one?
post #1250 of 4670
Yes you can reset your K/D but if it's like MW3 it will take you back to a level 1, no prestiges. So essentially I think you are starting all over again.
post #1251 of 4670
post #1252 of 4670
What does it mean by refund unlock tokens?
Edit: After reading a joystiq article, from what I understand is it allows you to reclaim all of your unlock tokens(and lock out anything you've unlocked with them) at anytime and reuse them as you see fit. This basically gives you the ability to open up several things, realize you've screwed up and are unhappy, and redo everything without all the work.
Is this correct?
Edited by RemoWilliams84 - 11/15/12 at 2:23pm
post #1253 of 4670
I think it just means if you spent all your tokens unlocking weapons and have none left, you can refund them so you can buy whatever you want instead. I don't think you have enough tokens to unlock everything throughout a single prestige.
post #1254 of 4670
Nice... I can tell you now it will be Ghost and an extra class for my first. The UAV's are killing me when I play solo and I feel like 'm the only one taking them down. The I team up with the avs crew and they aren't up for more that a couple seconds cool.gif
post #1255 of 4670
This game feels a bit to much like MW3. All maps are so small again. Really wish they didn't take that route. Oh well. Bright side. Zombies are just insane! Love it. Tons of fun. Can't wait to see the improvements they will make make in future updates.
post #1256 of 4670
Haha, quite often I'm fighting with mystaphyer and blowfish to see who can shoot them down first. Mystaphyer and the fish are freaking fast. by the time i locate the UAV and get my laucher pointed at it it's already blowing up.
post #1257 of 4670
So true. Let the people w/ better headsets/connections take advantage of what they paid hard-earned money for. How would that be different than anything else in life???
BTW: that drone thing in your score streaks that you throw is AWESOME. I got 4 people w/ it on Nuke town!
post #1258 of 4670
I haven't used many of the attachments yet but the adjustable stock is amazing! I don't see wanting to go without it for quite some time.
post #1259 of 4670
I know it's ridiculously early, but I wouldn't be surprised at all if they nerf the FAL. I put the rate of fire selector on it, set it to full-auto, and it was somethin' else. Even w/ the added(very slight) recoil, it's still more accurate than 95% of the other guns+ high damage/range. If you throw a grip on it, it negates that completely. I was using full auto/grip/silencer/blind eye/cold-blooded in free-for-all and simply cleaning up. I played mosh pit on Nuketown, and things still went very well, even w/all those people running around. If you put a dot sight in it instead of a silencer, I bet you could almost snipe w/ it.
post #1260 of 4670
Loving the game right now but it feels like you play the same maps twice all the time.
  Back to Forum: Xbox Area
