AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Call of Duty: Black Ops 2
Call of Duty: Black Ops 2 - Page 57
post #1681 of 4670
Originally Posted by bbexperience View Post
Well, in this case by camping I meant patrolling an area. Like on Hijacked roaming either upper deck or the little building on the side. So you're not really sitting still. You're "protecting the area". You should know all about this. biggrin.gif
Lol, I can "protect an area" like a boss. No way have I ever run in circles upstairs on hijacked........................
post #1682 of 4670
so i am loving the 870 but need a "long range" pistol for my secondary.. what do people like?? never ran a secondary weapon up to this point..
post #1683 of 4670
Long range none of them are great. Tac45 is a little stronger up close, but the five-seven is just as good at a distance and has 20 rounds. Best overall for range is the b23r, since its 3 round burst and pretty accurate.
But if you want a genuinely useful med-long range weapon, use overkill and an assault rifle.
post #1684 of 4670
thanks.. don't want to use 2 slots for overkill... so i will try b23r...thanks again
Edited by benjamin-benjami - 11/27/12 at 11:21am
post #1685 of 4670
Forget worrying about using a specific pistol and just pick up the weapon off the first person you kill with the shotty. Your mindset should literally be pull trigger, kill enemy, switch weapons, take enemy weapon, now have longer range 2ndary weapon + shotgun without using the overkill perk. I generally run a RPG or Stinger as my 2nd class weapon and I try to use it as soon as possible for the reason I just listed. I consider myself having 3 primary weapons, if I can get that first kill over with sooner than later.
post #1686 of 4670
That usually works pretty well too, I could probably rely on that in some of my classes. But in an emergency, you can swap to a pistol and ADS much faster than anything else Its like three times as fast, often the difference between life and death. Whenever you pick something up off the ground, you usually have to reload it, swap back, etc....pistol is always ready in a snap when you need it.
post #1687 of 4670
that makes sense.. i can't believe i didn't think about that!!!
post #1688 of 4670
HOW THE HELL ARE YOU ALL EVEN USING SECONDARIES?
Sorry for yelling but I die so much in this game I rarely ever run out of ammo in my primary. The occasions that I have is when I pick up a weapon off a body. (or floating in mid-air).
Multi-Team is the new family favorite. My GF who is usually in bed by 9 stayed up till 10:30 with me and my cousin. When we got off she says "now I know why you play so dang much".biggrin.gif
post #1689 of 4670
Plus with one primary you can switch to your combat knife at the opening and rush "B" (or other objective). Without Extreme Cond you get a good extra 50-75% more sprint time; with Ext Cond you should be there and swapped back to your primary in no time.
post #1690 of 4670
Yep...my flag rusher class is the only one where I deliberately don't use a secondary, to get that extra sprint distance. Only prob is when I run dry, I still swap by instinct, and I might as well be holding my **** in my hands.
post #1691 of 4670
Good point. People don't always realize that the cool thing w/ the pick-10 is that even if you max out your points(use NO secondary at all), you can STILL pick up a dead enemy's weapon. It's basically like getting an extra 2pts added to your class. When I run my LMG class w/ no secondary at all, I just grab one as soon as I can!
post #1692 of 4670
Never thought of that. About half my classes have a launcher for shooting down air support, the other half I don't carry a secondary at all. Never thought to pick up a dead enemies weapon with my shotgun class.
post #1693 of 4670
I don't use any secondary on any of my classes. I usually run and gun and die before my primary ammo runs out anyway. For people who don't die so easily I would say equip scavenger and you're good to go with just 1 gun. I have gotten into the habit of picking up a secondary rifle (free Overkill!) ASAP each time I spawn as well. When I find I need a launcher to take something down I just switch to the default class with the launcher next time I die. I die a lot LOL. K/D <1 LOL so maybe not the best endorsement but it works for me for now.
post #1694 of 4670
I decided to try to set up a slightly higher score streak than I usually go with. (I normally have UAV, Hunter, Lightening) I went 32-7 in a KC game last night on Express. I ended up earning 2 stealth choppers and was a few feet away from a 3rd one. I was just about to collect 2 tags when I got taken out. Those points would have given me the Stealth for sure. The downside was it was on Express so there is too much covered area for the Stealth Chopper to take full advantage. Oh well, I was just pumped to be able to earn two of them in the same match. It was the first time I had actually earned one.
FAL w/Select Fire/Grip/Silencer
post #1695 of 4670
I run the the FAL with a select and a grip as well. Man this setup is the best I have used in any of the games.
post #1696 of 4670
Sorry about last night guys (buc/lizard and crew). My router crapped out on me twice and I decided to call it a night. Good games though!
post #1697 of 4670
Just curious, what does everyone have their sensitivity set too?
Mines at 6 at the moment.
post #1698 of 4670
14
post #1699 of 4670
Originally Posted by Skipdalou View Post
14
post #1700 of 4670
Oh, so now we're putting conditions on our questions. I see how it is.
post #1701 of 4670
NO problem man, when you got back on after the first drop, and I saw you disappear again I figured you were having some issues. Sad thing is the lag started to ease up for me on the last few rounds, so you didn't miss any of the lag :P
post #1702 of 4670
post #1703 of 4670
Originally Posted by vedderpj13 View Post
What does it go up to? I thought it was 10 and Conman said he was on 11 the other night. I thought we was just being a smartass. lol
post #1704 of 4670
14 is the highest. I'll try turning mine up tonight, 6 is way too slow.
post #1705 of 4670
Just checked out the Scuf controllers. I think I will be entering uber nerd status shortly. It will be interesting to see if it improves my play. As much as I have grown to love the FPS freaks I don't think they've made a damn bit of difference in my performance. For those of you using these controllers did they have a worthwhile impact on your play or was it more ergonomics?
Part that sucks is I just picked up a Halo 4 controller so I guess I'll just send it in. For someone like me that plays only Halo and COD what would be the recommended configuration?
post #1706 of 4670
I'd rather get a xim personally.
post #1707 of 4670
Don't know what made me leave that set up...
post #1708 of 4670
I just got my Scuf controller in the mail today, but I haven't given it a try yet.
post #1709 of 4670
I like this humor.
post #1710 of 4670
I just can't see myself using anything else unless they nerf it somehow. A few more Stealth Choppers again tonight.
Just had 3 straight games to end the night:
39-7 KC on Slums
32-12 KC on Hijacked
38-16 KC on Hijacked
I'm really hoping this run doesn't end!
  Back to Forum: Xbox Area
