Originally Posted by
Arlene911
My ReplayTV remote control is failing. When I hit channel guide the Replay box crashes. Cannot then be turned on or off, must then turn off power to the box to restart. Are new remotes available?
Thx, Arlene
If it is JUST when you press "Channel Guide" it could be that there is some corrupt data in the guide the RTV doesn't understand, so it hangs...
Had this happen back in the day when I EuroNews was in my channel lineup. There would be some obscure character in the gudie data, and any time that I would scroll by that channel, my RTV would re-boot.
The solution? Remove that channel...
I don't think your remote control is to blame here...
Cheers!
-Doug
