I recently purchased a pair of Monitor Audio RX-2s for a 2-channel bedroom system. My room is about 11' by 11.5' with an 8' ceiling. I had auditioned a pair of RX-6s (the only model the local dealer carries) and really like the sound, but figured the towers would be a bit much for my room and the sound would be very similar with the RX-2s. Also, since I have 2 subs, which I prefer to co-locate with the mains, bookshelves seemed to make more sense.
So here's the problem... the RX-2s sound great in the midrange, but the crisp, detailed highs I heard in the RX-6s don't seem to be doing the same thing in my room. It's almost as if the highs are choked off a bit, like the speakers can't really breathe. If I'm about 2 feet from them, they sound fantastic, but where I normally sit (about 8' away), not so much. I had a similar problem with my previous speakers, which sounded like they were behind a pillow. The Monitor Audios don't sound nearly that bad, but they just don't seem to open up. I'm running them with an HK3490, and I also have an Emotiva UPA-2 I could pull out and try, but I don't think it's a power/amplification issue.
Any input you guys have would be appreciated.
Maybe I should just go with a center channel only? kidding. As they are now, I can have them anywhere from against the back wall to 1' away from it (I've tried everything in between those and the sound was practically identical) and 2' from the side walls. Are you suggesting I try having them slightly asymmetrical with regards to the room? As in say 1 of them 2' from the side wall with the other closer or farther away?
