I will be upgrading to a Triad setup:
(2) Bronze OnWall LCR
(1) Bronze InRoom LCR
(2) Bronze OnWall Surround
May possibly get Silvers if I come across used ones.
Surrounds are rated at 100 watts max, InRoom (center) 150 watts, OnWall (LR) 150 - 200 watts depending where you look.
With the Onkyo rated at 80 watts per channel, will this be ok to power all five speakers? I like to listen to loud music to play throughout the house, and sound for movies is at a decent level, not as high as when I play music though.
I'm mostly wondering if I'll be needing an external amp to get the most out of these.
