AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Yamaha RX-V661 please explain zone2/b/front?
post #1 of 5
The manual is putting my brain in circles.
I get the basic idea, zone2 is another channel you can use independently. Not sure what zone b is and speakers B does not act right?
Most stereos have a A/B speak assignment. So does the v661 but it has no function? If I set a,b,a+b, or none all speakers still work?
I have speaker set to zone2 in another room, and my speakers front B go out back. currently there is source 1 on my main receiver. I set the zone2/front to font in the menus and out back I here source 2 out back. So I did something right. Though I can not adjust that volume. Now if I set zone2 in the menus I get my second room playing source 2 and I can set the volume.
So I guess what I'd like to know is how can I change the volume of the front B speakers. Also why does the A/B not do anything?
post #2 of 5
Zone 2 allows for an independent analog source/volume while the Front B will play the same source/volume as the Front A speakers (ie. Front A volume also controls the Front B speaker volume). Although Front B can be used in another room, it is designed for when using another set of speakers (for music only) in the main zone.
post #3 of 5
Sort of expected that, but its not playing what the receiver is. I obviously have a mess here...
( ok here is the deal )
My out door comes from zone2 RCA
My second room comes from speaker wiring zoneB/front
Now when I adjust the volume for zone2 the second room changes if set to zoneB but the volume for the zone2 ( RCA ) does not change. Can it?
Thinking it over, I dont see why RCA out would change volume. So I guess that answered that.
post #4 of 5
Doing a bit of reading, it seems that the Zone B is a method of placing the Front B speakers into another room; however, when used there can be no audio in the main Zone (ie. some kind of crazy Yamaha unique feature). This is why Zone B and Zone 2 audio changes are separate and distinct.
post #5 of 5
I have no idea what Yamaha was thinking here. But here is what I here.
Zone 2 is playing source2
main is playing source 1
Zone B is playing source2
This is accruing all at the same time. I dont even know what to think. All of this coudl have been a lot more clearer in my opinion.
